I am facing a problem with mapp Audit that seems to doesn’t register mapp AlarmX events.
I set the Audit trail like this:
I would expect that Audit register all alarms triggered by mappAlarmX. Am i I wrong?
It doesn’t work.
I already set BR_Engineer as role and already enable opcUa on Audit trail.
Where the mistake?
Thanks for the help!
Have you defined the Text for the event properly? Which versions do you use? Is there anything related to the mapp Services in the logger?
the text are shown correctly in mapp alarmX list so the AlarmX seems to work in the proper way.
Versions:
AS 6.5.3.11 SP
Below versions:
If I understand properly every alarm that happened can be registered by mapp Audit, right?
Can you try the latest versions of mapp View and mapp Services?
