Can anybody help to resolve this issue?
Hi Ananta, welcome into our community!
I will focus on configuration file Configuring the mapp View server. It could be the port 81 is already in use by another software installed in your laptop. Can you try to modify it to another port? Suggestions: 82, 83…
Then you would need to rewrite the path to access to your visualization.
localhost:port/index.html?visuId=myVisu
Have you also followed the mapp View getting started guide? Getting started - mappView
Issue resolved by changing port to 82 and rebuild the project.
Thanks for quick solution.
