Hi together,
at the moment I’m working on some tests with mappMotion for the first time. I want to cyclic read some ParIDs, but I only found a function for ACP10 (MC_BR_CyclicRead).
Does somebody know a similar function (+library) for mappMotion?
Thanks in advance
Jonas
Hi Jonas,
The function block MC_BR_CyclicProcessParID_AcpAx allows ACOPOS drive parameters (parameter IDs or ParIDs for short) to be read from or written to the drive cyclically, either individually or in a list.
Greetings,
David
This is an example for you. Not cyclic, but similar.
Thank you for your quick reply!
