MpTension Diameter Estimation Not Updating from Preset Value (Velocity Based)
Environment:
  • Automation Runtime: Q4.93
  • mapp Control: 5.24.3
Setup: I have MpAxisTension configured with an Unwinder and Winder. The Winder diameter is known and used to calculate line velocity, which I feed into the Unwinder’s ActLineVelocity input for velocity-based diameter estimation.
Problem: The estimated diameter never updates from the preset value despite:
  • DiameterEstimation.Active = TRUE
  • Consistent mismatch between SetLineVelocity and ActLineVelocity
  • Over 1800m of processed material
Configuration:
  • Utilization: Unwinder (Center)
  • Diameter estimation: Velocity based
  • Estimation window: 360.0
  • Filter time: 0 (initially default of 0.1)
  • Min diameter: 1mm / Max diameter: 10000mm (initially 115mm - 160mm)
  • Material: Wire (0.25mm diameter)
Runtime Values:
  • SetLineVelocity: 60 m/min
  • ActLineVelocity: 59.8 m/min and decreasing as unwinder diameter decreases
  • ActAxisVelocity: ~130 rpm
  • PresetDiameter: 140.0 mm
  • EstimatedDiameter: 140.0 mm ← Never changes
  • DiameterEstimation.Active: TRUE
What I’ve verified:
  • Units are correct (m/min for line velocity, rpm for axis velocity)
  • ActLineVelocity is updating
  • Velocity ratio suggests diameter should be calculated differently than preset
  • Reproduced in simulation with direct variable linking (SetLineVelocity + offset → ActLineVelocity)
Screenshot of simulation run with 10 m/min setpoint and -.5 m/min actual velocity offset:
Has anyone encountered this behavior? Any insight into what conditions are required for the estimated diameter to actually update would be appreciated.
I was not able to figure out why velocity-based diameter estimation did not work, but I was able to get position-based diameter estimation functioning with the same configuration.
