Request for Technical Information on ACOPOSmulti Inverter Current
Dear B&R Support Team,
I am using B&R’s ACOPOSmulti inverter and have encountered some difficulties in checking the current parameters of this device.
I would greatly appreciate it if your technical team could provide me with the relevant current specifications for the ACOPOSmulti inverter. This information is crucial for me to ensure the device operates stably and efficiently during usage.
Thank you very much for your prompt support.
Felix.
you can find current specs for the ACOPOSmulti inverters in B&R website (for example for the 8BVI0014HWS0.000-3 here, tab “Technical Data”).
Thank you for your reply, and sorry for my confusion earlier. What I meant is the actual current when I test the motor. It’s like observing the current when running the motor and using an ammeter to compare and see if they correspond.
Best regard.
mapp Cockpit is used for tracing Acopos ParIds. You should trace ParId 214. Links to the help:
thank you very much!
