RFID new version of program, library update
please, I have two questions for you.
  1. I use RFID reader in C50 panel. Code of RFID program is from 2009. I want to ask if I can find a newer version somewhere? For example, this version is used with library asstring, which is no longer supported in AS6.
  2. Next question is about library. Where can I download newer vresions of libraries? I mean the ones in the screenshot.
Thank you for help.
Libraries come with the runtime version. Whenever you switch to a new runtime the libraries will switch as well. Take a look at this example for RFID, maybe you can use something from it.
br-automation-community/mappView-User: User management using mappView and the ArUser library
Hi @jhospodka1, have you found a solution for your issue? Can you update us and maybe close the topic?
Hello @jhospodka1 ,
Can you send me this program ?
Thanks,
Tung
