SafeDESIGNER cant be opened with safety module X20SLX842
Hello everyone, 'm trying to access safeDESIGNER but I can’t; it keeps showing a red error. I currently have safeDESIGNER version 4.3 and Automation Studio version 4.12 installed, so there shouldn’t be any incompatibility between safeDESIGNER and Automation Studio, right? Can anyone help me with this?
I am assuming you are trying to use mapp Safety here instead of the older Safety Release. You can check this from the Project → Change Runtime Versions menu.
The error message is telling you that there is no Safedesigner project assigned. It should be added to the configuration view, instructions from Automation Help: Configuring mapp Safety
The above link is a part of the Getting Started guide for mapp Safety. I would suggest you to follow this step by step.
Thank you so much for showing me how to solve the problem. I have updated mappSafety to the correct version of safeDESIGNER.
