Hi Community,
I would like to ask if any of you know how to offset a SuperTrak target during runtime. I’ve tried using StTargetExt, but I haven’t been able to achieve any success. For this purpose, I’m using the Automation Academy SuperTrak demo, which works with this function block.
Thank you!
SOLVED
The problem was solved by overwriting the SuperTrak parameter ID.
You can use the “Solution” to mark you solved Post. Through this, the whole thread is marked as Solved.
