Uninstall mapp View and Services 5.13?
I have installed AS4.12 and had to install mapp Services and mappView 5.13.1 for an old project. Now I have updated the project to mapp Services and mappView 5.24.x and want to remove mapp 5.13.1. Unfortunately, I cannot find a way to uninstall mapp 5.13.1. Does anyone know how to uninstall mapp 5.13.1?
Hello Walter,
Are you saying that the mapp View version stays the same even after defining the new 5.24.x, and the compiled program doesn’t update the system?
Either way, it will be faster to approach the local B&R application for immediate support.
Eren
Hello Eren,
the update was successful, and the compiled program is now on 5.24.x.
But in AS I have two mapp View versions 5.13.1 and 5.24.x, so I want to remove the older mapp View 5.13.1 from AS.
There is no seperate uninstall. You can manually remove a folder in \AS\TechnologyPackages\mappView.
as @corne.geerts mentioned, this is the only way how to get rid of old mapp/mappView versions.
