Upgrade AS3 to AS4 with safety PLC
Hi, I have a AS project written in V3 and want to convert it to V4
I have done this before, but this one has a X20SL8001 safety PLC running safety release 1.5
Is it possible to convert this to AS4?
I can’t find any safety releases under AS4 which will work
Thanks,
Brian
Hello and welcome to the community,
There is a GUID (9e1174fd-16da-4891-9ca1-c8f16a547120) in AH 4.12.7.90 with a link to a PDF document named releaseinformation.pdf.
releaseinformation.pdf (166.7 KB)
Thanks Pavel, looks like none of the safe designer versions work with Windows 11, so it’s a non-starter
All the best,
Brian
The only compatible combination for Windows 11 is SR 1.10 + SafeDESIGNER 4.4.1. See this topic.
Thanks Pavel
Our safety PLC is X20SL8001, so no SD for that and Windows 11
Brian
