Upgrade on 2023b wants MinGw-w64
Hello Everyone
I updated my software to the target-for-simulink V6.9.1 and matlab 2023b last week.
At the end of updating, i wanted to check the matlab project upgrade.
There, matlab informed me i would need MinGw-w64. I checked with the old B&R install guide. There a C/ C++/ Fortran LLC like MinGw-w64 was recommended.
So i installed it, but since the installation, the build process does not detect the B&R config block in simulink.
Did anybody encounter this as well?
Did the installation of MinGw-w64 change the simulink model settings for the compiler?
And if so, is there a possibility to revert the simulink model settings to see the B&R config block?
Lukas
Do we have any target-to-simulink expert here in the community? Who can help Lukas?
Hi, what is the status of this topic, have you found solution for you?
Closed as a unsolved due to inactivity
