Kindly I have issue with two applications on same network and sometimes have same error for the two application on same time for Visual component crash runtime
Not sure how to help you, there is no magic trick that will fix app exception. Just two hints I can see from your picture
- VCWT 4.06 is very old, the latest one s VCWT 4.72
- I noticed Windows error message from network, could it be that exception is trigger by this?
Hi @Ibrahim_Youssef, have you in the end found solution for your issue, can you update us?
