Hello everyone, I am a system administrator at the plant. The Aprol system is installed. I want to change the settings of the trolley under the bunkers. I got to the settings window, but the field is not editable, which way should I dig?
Hi @Andrew_Manila, have you found solution for your issue? Can you update us? Thanks.
closed due to inactivity
