How many Ethernet IP slaves can be managed by this module. Are ther known limitations in buffersize, physical limiits etc.
Thank you very much Oliver.
I will supplement the answer from Oliver by including another common (but not technically an X20IF10D1-1) limitation when using the X20IF modules.
If you are using the X20IF module on an X20BC1083 POWERLINK Bus Controller, then the whole bus controller is limited to 1488 bytes in each direction (a PLK node limitation).
This is documented in the AS Help.
-Austin Carpenter
You are welcome ! If you need further details please let us know
