hello,
is it possible to select the digital output voltage in the X90 controller?
is there any way to change it by any of the X90 supplies? V_I/O?
thank you.
hello,
thank you.
it is not possible to select the output voltage of a single digital output channel.
If lower voltages are needed you can either use the analog or PWM outputs.
The V_I/O supply is affecting more than the output voltage of the digital outputs.
thank you for yor answer.
