Dears,
Customer use B&R Linux in the APC3100 after power surge CPU always starting in DIAG mode.
Issue in the software or do need replace de Cfast card ?
Thanks a lot
Hello and welcome to the Community,
You should check the reason why the APC is in DIAG mode. You can do this in the logger section of the SDM; see help. Alternatively, create the System Dump and open it in the AS logger.
HI @TrovaoNP, have you found usable solution for you, can you update us?
