Does anybody know if it’s posibble to run automation runtime embedded in a container ?
We whant run multiple instances in on a virtualization platform for Simulations.
Best regards Wouter
Best regards Wouter
I know that it is possible to run ARsim’s multiple times on a Windows. It can also run independent of Automation Studio.
Multiple use of ARsim in Windows + Loop Back Adapter
I do not have informations about Docker, …
HI @Wouter_Delfgaauw , can you please update what is the status of your topic and maybe marked answer that helped you most as a solution?
thanks
