Automation Studio 4.12 license activation fails in VM: “License Central login failed”
Hi everyone,
Customer trying to activate a B&R Automation Studio license in a virtual machine, but activation fails with the error “License Central login failed” (see attached screenshot).
Has anyone encountered this issue in a VM? Are there any specific network, proxy, or VM configuration requirements for license activation?
Any troubleshooting suggestions would be appreciated. Thank you!
As far as I know.
CodeMeter Runtime must be installed, and the CodeMeter service in Windows must be running. I recommend restarting the service once and trying activation again. B&R documentation states that licensing depends on proper initialization of this service (WIBU CodeMeter).
Please also verify the VM system time (date/time/timezone). Incorrect time settings can cause TLS/authentication failures.
Finally, use current versions of Automation Studio, Technology Guarding, and CodeMeter Runtime, since older versions may fail during online login/activation.
Troubleshooting references (AS4 Help):
Hello @shenyang.zhou
This may also have been a temporary issue with the B&R license server.
Please try the licensing process again; the problem should be resolved by now.
If you still have problems with the licensing, the suggestions by Jaroslav would be the way to go.
Best Regards
Alexander
hi @shenyang.zhou any update there?
Thank you all for your replies. I’ve passed the suggestions on to the customer, but they haven’t responded yet. I also think it might be a network issue. I’ll update this thread if I receive any further feedback. Thanks!
I came to my customer he resolved this issue by updated the codeMeter software.
Thanks!
