Automation Studio 6 - How to install PPC80 from project created in AS6?
Could you help someone about of the AS 6, i make a test program and install the 4PPC80 and start up the panel and i get only the B&R logo. there is no login and i cannot continue . anybody know how to enable or disable the start up login field?
Hi Jaroslav,
of course i done the first steps to install the OS with USB, but when i done a dummy project with 2 pages from visu, i have this problem. if i will open to browser everything is correct, the problem is only to C80 PP. in order to help you, i have connected and a terminal T30, which i have configured to web and that works very good.
pls see the attachment photos, maybe you help.
the first one is when it was finished the installation and the second one after reboot.
