B&R License activate show error: For CmActLicense the CodeMeter License Server must run as a service, Error 267.
Hi Nagarajan
Make sure the codemeter service is running, you can check this via the processes tab in your task manager:
If not, you should be able to start it manually.
If it’s not in the overview, you might need to install the technology guarding tool again:
download B&R technology guarding
Good luck!
Jan
Hi @nagarajan.k were you able to fix this with Jan’s suggestion?
Closed due to long inactivity. Feel free to reopen it if needed.
