Can a single braking resistor serve two ACOPOSinverter P86 drives?
Question:
We have two ACOPOSinverter P86 drives (5.5 kW and 37 kW) sharing a common DC bus. We plan to connect a single braking resistor to the 37 kW drive. Can this braking resistor also absorb the regenerative energy from the 5.5 kW drive?
Answer:
This configuration is supported and documented as a valid use case by the supplier.
