Can I Replace My 4ppc80.101E With A Larger Screen Model?
Hy there,
i have there a configuration. For root there is used a 4ppc80.101E.xxx. I need to change it to 4ppc80.156x… The systemdesigner does not allow to replace it.
My situation is inside this configuration there are up to now many settings done , especially in mapview. The replacement ist necessary because of a bigger screen. When i take a new configuration all those settings have to be made again. Is there a easy going way so i don´t need to do all the mapview configurations new.
I tried to change the hardware and in second step just do some adjustments in the layouts…
Is there any possibility?
Hello Raimund
A possible issue is that your ArSim is running/activated. This prevents you from changing the hardware.
Good luck!
Jan
Hallo Jan,
thank you for your advice. The change at least was successful by switching of arsim.
Thank you
do I understand it properly that your problem is solved?
yes, the problem is solved.
