Hello, everyone.
A Panel PC 3100 with Windows 10 version 1809 started restoring previously deleted files and excluding new files with each new restart of the OS.
I have already checked the UWF (Unified Write Filter), and it is disabled. The CFast is not write-protected (or in read-only mode), according to DISKPART. And the Crystal Disk Info tool shows that the card is “healthy.”
I tried to use the Windows Recovery Solution tool, downloaded from the B&R site. When the formatting process starts, an error occurs (see attached image). I have already booted the PC using both UEFI and legacy USB modes.
Is this an indication that the CFast is damaged?
