Is there a way to check if Raid 1 is activated on a Automation PC 910 without going to the BIOS?
In the explorer I can only see one Harddrive (which is correct with the use of Raid 1 I assume).
Due to inactivity this topic will be marked as solved. @adrian.knoepfel if the topic is still open, please add a reply here with the latest status and the answer to Marcel’s question. Thank you!
