Configuring TSN switch
I am writing my thesis on TSN. How can I connect to switch 0ACST052.1? I need to configure traffic scheduling (Time-aware shaper) according to the IEEE 802.1Qbv standard. I don’t want to use OPC UA. Is it possible to configure this somehow?
Hi Matej,
if you don’t want to use UA Expert, in the Manual TSN Switch User’s Manual | B&R Industrial Automation mention, that you could use NETCONF or TTech Slate XNS
BR
Vanessa
Hello
Here you can find the user manual:
You can also configure the switch via NETCONF.
Standard use-case is, besides the initial steps described in getting started, to configure the TSN switch with Automation Studio.
But alternatively you could also use other tools, e.g. TTTech Slate XNS is mentioned in the manual.
Lg Michael
Hi @Matej_Krumlovsky, have you found the answer to your question? Do you need anything else?
I tried use UA Expert but i dont know if its possible with NETCONF its little bit complicated do you have some advice for that or some instructions to help me how to do that? I need
to configure time-aware shaper which is standard IEEE 802.1 Qbv.
Because there is no activity from the Community, I think the best thing is if you get in touch with local B&R support.
