Hello, I have no experience with B&R devices. The CPU model X20 CP 3584 in our machine has malfunctioned. If we replace it with the X20 CP 3585 model, will the system work properly when we insert the existing SD card? Will it maintain compatibility, or will any configuration be required?
Hello @qqqq.2000 ,
unfortunately not. You must be in possession of the corresponding Automation Studio project. Then you can simply replace the CPU, compile it and you’re good to go.
