1、Do permanent variables work properly when the PLC battery is low?
2、Does the use of permanent variables affect CPU life?
Also a condensator backups the SRAM, but only for a shorter time.
So when the battery is low and there is no power for some time the SRAM and permanent and remanent data is lost.
The use of permanent/remanent data has no influence on the CPU life.
Some newer products only have remanent data and no permanent data.
Please specify what PLC type you are talking about. That can help us give you a better answer.
CP1585、CP1586 and CP3687X
