I am getting the following error when trying to open Automation Studio file V4.9
Any quick fix suggestions?
Thanks @KSinada ,
I see your request in our Support inbox.
Hi @KSinada , were you able to resolve your issue after sending the request to Support? If so, it would be great if you could provide an update on what the resolution was.
I was told to delete temp/Diagnosis/Binaries folders of the project as a simple fix first, but that didn’t actually work for me. Second suggested fix was to re-install
Automation studio which fixed my issue.
Hi @KSinada , thanks for the update. Please mark your comment as the Solution for this topic, thank you.
