Subject: Technical Support Request: Automation Studio 6.5.1.7 Crash on Startup (pg.exe - System.Xml.XmlException on Windows 11)
Dear B&R Technical Support Team,
I am experiencing a critical issue where Automation Studio 6 crashes immediately upon startup.
My environment setup is as follows:
OS: Windows 11
Software Version: Automation Studio 6.5.1.7
During the initial installation process, I noticed multiple “Copy failed” errors in the installer log, specifically when copying localized help and release information files (Help-de, Help-en, RevInfos). Although the installer finally marked the process as “Completed,” the software fails to launch.
When I attempt to run Automation Studio 6.5.1.7, it crashes instantly. I checked the Windows Event Viewer and found two related error logs (.NET Runtime and Application Error).
According to the logs, pg.exe terminates due to an unhandled System.Xml.XmlException inside BR.AS.UpgradeCore.UpgradeDataProvider.LoadData. It appears that some configuration or upgrade-related XML files were corrupted or incompletely written during the faulty installation.
I have attached the detailed Windows Event Logs below for your reference:
[Event Log 1: .NET Runtime]
Application: pg.exe
Framework Version: v4.0.30319
Exception Info: System.Xml.XmlException
Stack Trace:
at System.Xml.XmlTextReaderImpl.Throw(System.Exception)
at System.Xml.XmlTextReaderImpl.ParseDocumentContent()
at System.Xml.XmlTextReaderImpl.Read()
at BR.AS.UpgradeCore.UpgradeDataProvider.LoadData(System.String)
at BR.AS.UpgradeCore.UpgradeDataProvider.Init()
[Event Log 2: Application Error]
Faulting Application Name: pg.exe, Version: 0.0.0.0
Faulting Module Name: KERNELBASE.dll, Version: 10.0.22621.6133
Exception Code: 0xe0434352
Faulting Application Path: C:\Program Files (x86)\BRAutomation\AS6\bin-en\pg.exe
Could you please guide me on how to completely clear the corrupted cache/XML configuration or resolve this installer-induced crash on Windows 11?
Thank you for your time and assistance. I look forward to your urgent response.
“Please note that I have already tried completely reinstalling the software 7 times, but the exact same crash persists every single time.”
