Automation Help
Automation Help includes support for the most common problems with Tools => Upgrades.
Automation Software => Project Management => Workspace => Upgrades => Troubleshooting
Fire wall / HTTP / TLS
So far we only had one single case where a customer ITs firewall blocked our upgrade service that couldn’t be solved by the customers IT themselves. The Upgrade service accesses our homepage to download the upgrade files and allowing this the problem was solved.
User rights
Automation Studio
As a test it should always be attempted to start AS explicitly as administrator. Some operations of AS always need administrator rights, see Automation Help:
Automation software => Software Installation => Administrator rights for B&R software
Upgrade Service
Tools => Upgrades relies on the B&R Upgrade Service for operation, see services in Windows.
Note which user (e.g. LOCAL_SYSTEM, LOCAL_SERVICE,…) is used to run this service. The customer IT must ensure that this user has sufficient rights to:
- Access B&R homepage
- Download files (including zipped files) into C:\Temp
(e.g. this file is downloaded: https://www.br-automation.com/addons_xml.zip ) - Unzip files in C:\Temp (and subfolders)
- Install the upgrade files from there
In some cases switching the user from LOCAL_SERVICE to LOCAL_SYSTEM or vice versa could solve the problem.
Known problems
List of HwUpgrades in Tools=>Upgrades outdated / not updated anymore
In rare cases it could happen that the list was simply not updated anymore, even restarts of the PC could not fix this. (Deleting everything in C:\Temp and restarting the PC normally does fix the issue)
The problem itself was never reproducible in HQ so a definite fix could not be found but based on the available information several improvements were made and introduced with AS 4.11
==> All further analysis must happen with AS >= 4.11
==> To rule out interference of older AS UpgradeServices no AS < 4.11 should be installed on this test system
==> Provide as much information as possible including all the logs listed below
Information for further analysis
Tools Upgrades Logging
Some components of AS can activate a logging function. In location C:\Users<username>\AppData\Roaming\BR\Logging\Settings there are config files for this
functions.
The Level in the configuration file controls what is recorded. 1 = Information, 2 = Warning, 4 = Error, 8 = Debug ( Sum 15 = everything)
After Saving of changes in this file and a RESTART of the application (AS and Windows Service) the logged files can be found here:
C:\Users<username>\AppData\Roaming\BR\Logging\Data
Attention: The Logging should be deactivated again after it finished to avoid performance loss and creating unnecessary files.
LOCAL_SYSTEM
If the upgrade service is started as “Lokales System” (LOCAL_SYSTEM)
2 of the relevant files are here: C:\ProgramData\BR\Logging\Settings
BR.AS.UpgradeCore.config
BR.AS.UpgradeService.config
And another one here: C:\Users<username>\AppData\Roaming\BR\Logging\Settings
LOCAL_SERVICE
If the service is started as „Local Service“ the Logging is stored here:
C:\Windows\ServiceProfiles\LocalService\AppData\Roaming\BR\Logging\Data
Data for B&R Support
If you can’t get this to work together with the customer IT please do the following test and take a video (fullscreen, not cellphone) of the whole test:
Close all instances of AS
Activate full logging as described in the attached PDF
Stop all B&R Upgrade Services
Delete everything in C:\Temp
Start one B&R Upgrade Service of the AS version you want to test, the latest installed AS version
Wait 1-2 minutes to allow the service to download the upgrades list from the homepage (you can pause the recording of the video here)
Check the contents of C:\Temp and subfolders and compare them to a working PC
==> If there is no “asupgrades.xml” or “addons.xml” then something on the customer’s PC is blocking our service -
Start AS explicitly as Admin
Try installing some online upgrade
Try installing some local upgrade
Access our homepage with some browser
==> Provide this video and all the logfiles described above.
