ACOPOStrak Innovation Update 2026
This is a technical overview of the ACOPOStrak system — what we have had for a long time, as well as the innovations introduced.
1. System Architecture
The ACOPOStrak system is based on a long-stator linear motor, with two main components: the magnetic unit (rotor) and the segment (stator).
The magnetic unit comes in two sizes (45 and 90 mm), matching shuttle widths of 50 and 100 mm, and provides propulsion and attraction force.
Segments are fully welded stainless steel parts, available in five geometries: straight, curve entry, curve exit, circular arc, and compact curve. These allow layouts in two grid systems (660 mm and 330 mm).
Segments are available in IP65 (standard) and IP69K (washdown) protection, supporting demanding hygienic environments (e.g., dairy, poultry).
Segments can be cooled (liquid) or non-cooled (natural convection).
2. Shuttle and Guide System
Shuttles are available in two sizes, matching the magnetic unit.
Variants include single or double magnet (for diverting), with plastic or metal wheels.
Plastic wheels enable hot-swapping and a minimum product pitch of 50 mm.
Metal-to-metal wheels increase payload up to fivefold but do not support diverting.
The standard guide system uses stainless steel (1.4404); for metal wheels, hardened steel guides are used.
Lubrication options include automatic guide lubrication or an oil reservoir in the shuttle.
3. Customer Adaptation
- For applications with extreme hygienic or mechanical requirements, a customer design package allows users to design their own shuttle mechanics, following specified parameters (air gap, position, forces).
4. Software Layer
The system is controlled by the map track software layer, enabling advanced shuttle movement, synchronization, collision avoidance, diverter control, and shuttle count.
Focus is on simplicity and robustness, especially during line changes.
New function blocks are being developed to simplify and accelerate system deployment.
5. Technical Innovations
Metal-to-Metal Shuttle: Introduction of shuttles with metal wheels and rails, mechanically clamped and spring-loaded. This significantly increases payload (up to 10 kg for large shuttle) and dynamics (acceleration, curve speed), especially with the compact curve.
Compact Curve: New segment geometry with a smaller radius (330 mm), fully welded, always in washdown (IP69K) version, enabling higher density and throughput. Compatible with both metal and plastic wheels.
Hybrid Solution: Combines linear motor for dynamic sections and conventional transport (belt/chain) for simple transfer. The new approach allows contact between belt/chain and shuttle, reducing forces and increasing cost-effectiveness. A temporary “bridge” segment with limited dynamics and half the price is available until the full hybrid solution is released.
Safety and Collaboration: Patented solution enables safe human collaboration with the system using safe drives with limited speed and force.
6. Configuration and Support Tools
→ To discuss the best configuration for your application, get in touch with your sales representative.
The sales tool enables complete system configuration, including guide variants, segments, shuttles, and offer generation.
The system automatically checks component compatibility (e.g., washdown segments cannot be combined with standard guides).
Data packages with CAD models, assembly instructions, and software files for simulation and real operation are available.
7. Planned Extensions and Support
- Portfolio expansion is ongoing — ask your sales representative or join upcoming a technical webinar.
Conclusion:
ACOPOStrak offers a modular, highly customizable transport automation solution with a focus on modularity, dynamics, payload, and integration simplicity. New technical innovations (metal wheels, compact curve, hybrid solution) expand deployment options across industries and increase system competitiveness.
Software support:
ACOPOS track monitor
ACOPOS track designer
