Can we drive an axis in closed loop using an asynchronous motor and encoder using the Mapp technology block (like MpAxisBasic)? If so, what configuration method should we follow?
Yes, with ACP10 based motion, you can use the SDC technology in the PLC/Drive. If you are mapp motion, it can be done, but I’m less knowledgeable on that.
additionally the online help in regards to the motor parameters
