Hi everyone, I’m having an issue with a PP65 HMI. It doesn’t start and gets stuck on the startup screen. Any help would be appreciated!
You need to connect with Automation Studio to see what is in the logbook. The issue might be in the panel or in some external hardware missing.
Could you please explain how to connect the PP65 to Automation Studio? Thank you very much.
The PP65 has an Ethernet port. That’s probably the easiest way.
True okay Many thanks .
Your power panel is in service mode. Here is detailed descripton what is it about. Service Mode - What is it and how to collect diagnostics
