Pp65 hmi stops responding
Hello everyone,
I’m having an issue with a PP65 HMI. After it runs for a long time (for example, about 4 days), it freezes and stops responding. When I restart it, everything works fine again.Does anyone know what could be the cause of this?
Thanks in advance.
Set up the profiler to store it’s most recent data through a power cycle. After you reboot, you should be able to then check what tasks were executing or what the idle time is.
Check how to set profiler properly. How to create a long profiler with enough data for analysis You can also try to read logger, this is also partly described here Service Mode - What is it and how to collect diagnostics
Thanks for replying guys
Any progress? can you update us?
Please verify the exact condition.
Is the control still in RUN mode, with only the display unresponsive?
Or is the entire CPU truly in a state where nothing responds at all?
In any case, be sure to thoroughly review the entries in the logger!
I marked Martin’s answer as a possible solution for investigating your issue. Feel free to update us with any findings you discover.
