Regarding revision of PLC card and Base of B&R
Item/Equipment Rev. Provided(User) Rev. Given(Supplier)
X20BB80 E0 E3
X20BM11 J0 J3
X20DI9371 G0 I0
X20DO9322 I0 L3
X20AI4622 J0 P6
X20AO4622 L0 N0
X20AT4222 V0 X8
X20AT6402 I0 M3
Dear B&R community,
Here i have attached B & R specific model and revision. please help me that the revision given by supplier is exact replacement of revision given by user. Right?
There be only plug in and play will happen. Right?
The Revision of the Hardware indicates a difference in Hardware Design. A Change in Hardware Revision does normaly indicate a compatible difference.
If you want to check the Revision Change Log you can Login on the B&R Website and search for the Product.
I can not share this data here because the Community is Puplic. Therfor only the indication were you can find the information.
If you do not have a login to the B&R Website, please reach out to your Local Sales contact and request a access.
In General you will always get the current Revision from B&R, to get a Module with an older Revision is not planned.
