Run an application on a PC without automation Studio
Hi
Few years ago, it was possible to run an application on a PC that doesn’t have automation Studio. I gave a special file that I found under temp folder. I don’t remember how to do it. Is it still possible to do it? If yes, can I get instruction. Thanks
ProjectPath\Temp\Simulation\X20CP0484\X20CP0484 is an example of the folder you will need. This has the entire ArSim runtime inside it, along with system and application partitions.
Just run the ar000loader.exe file.
That is basically it.
thanks for your quick answer
