Quick question regarding the RWS library (BrAbbRws).
Does anyone know if this library is only supported on Intel Atom processors and not on ARM Cortex?
I tested it on an X20CP1586 (Intel Atom) and it worked fine. However, when I transferred the same program to an X20CP0482 (ARM Cortex), the compiler threw multiple errors such as:
We have tried this library a few years ago and was the same with ARM processors, so if you have to use it, you should stay with Intel processors, or use some other interface.
