Safe Designer Compile issue?
i have AS 6.5 with MappSafety/Safety Designer 6.4.2 and previously was possible to compile simple Safety program,
now after few weeks and some updates of AS/Firmwares Safetuy program can’t be compile
i get 2 error:
Internal Error 1050! Task ‘TASK’ Not included in resource! call technical support. (Specific Code Generation)
Internal Error 1083! Cannot read file ‘xxxxx Proj directory \C\PLC\R\CPU\CPU.SET’ call technical support. (Specific Code Generation)
solved issue.
while using github, and gitignore configuration have been defined ignore *.set files, that broken Safety.
In case anyone comes across this thread later and wants some more information:
.gitignore file for AS projects - Share Info & Ideas / How-To & Wikis - B&R Community
Using version control systems
