Upgrade PLC and runtime version
I would like to replace the 4PP420 PLC (Runtime 3.0 project) with a T30 PLC (Runtime 4.1 project). Are there any specific points I should pay attention to or settings that need to be adjusted when upgrading the runtime?
Thank you.
The very first thing you have to take into consideration is that PP420 was power panel (CPU+panel) but T30 is only terminal. So for T30 you will need PLC and host visulization using VNC server.
