Hello, I’m Choi.
I’m Using X20CP0484 CPU.
It takes about 27 seconds for the CPU to boot, but with a USB plugged in, it takes 57 seconds. Any idea why?
it’s CPU Parameter.
Thank you.
Hello, I’m Choi.
it’s CPU Parameter.
Thank you.
maybe because you are trying to mount a USB stick as a FileDevice ?
Can you perhaps remove this ?
@Choi_Haechang
if you still need to mount the stick you should do this dynamically.
find a sample here
