hi Guys,
After a recent windows upgrade, I have started getting error as attached while compiling an AS project with DTM devices.
It Says "Could not load resource file. Error Code 0x80040154.
Has anyone faced this issue and found any solution?
Thank
ASK AI:
The Error Code 0x80040154 is a Windows-specific error code that typically indicates a problem with the registration or loading of a component or resource file required by your application. In the context of compiling a project with DTM devices, this error might suggest that a necessary DLL (Dynamic Link Library) or COM (Component Object Model) object is either missing, corrupted, or not properly registered on your system after the Windows upgrade. To resolve this issue, you may need to reinstall or re-register the required components, or check for updates to ensure compatibility with the new version of Windows.
Thanks Jaroslav,
The problem gets temporarily solved after reinstalling the DTM library. But it appears again after a reboot. How can I know which component is missing? Is there any log which can show what is missing?
Shailesh Holani
have you found solution for your problem?
no, I have not found any solution yet.
ok and have you contacted local B&R support?
