Working with ACP3100
I have now successfully uploaded the project program through the Cfast card, and have the power and Run led showing a solid green status and indicator, I can ping the IPC through the IP I have assigned it but I still cannot connect to it through AS by going into the online settings it does not pop up.
If anyone has any troubleshooting suggestions they would be greatly appreciated.
The browse for targets only works if the Acivate SNMP setting is activated.
You are able to ping the ACP3100, so you could also add a new TCPIPconnection and define youre defined IP-address.
Thank you, I’m online now!
