XY Chart Rotation
Hello There,
Is it possible to rotate an XY chart 90 degrees?
I am using it for a plastics application to generate a profile, but I need it to present vertically.
As there is no “Rotate” option associated with the XY chart, is it possible to develop it in a content and rotate the content 90 degrees?
Thanks for any help!
Hi @Elwin_Justice , maybe someone from community has some workaround for you, so lets wait for it.
In meantime, can you share with us what exactly you would like to achieve? I mean you can swap X/Y data, but this is obviously not enough for you I guess. I would like to share your use-case with development team. And for this I need to know what exactly should be the output and why.
Hi @Elwin_Justice,
I think there is no rotation parameter in XY chart. However you can swap X and Y values, that way you will have the graph vertically as you want.
Example:
Parameters swaped:
You can also play with position parameter top/bottom/left/right in xAxis/yAxis configurations.
Hope this helps!
Xabier
Hello Elwin, I wanted to ask you, where did you find the “fill color” for the area under the curve for the XY Chart, I thought this was only possible for the LineChart widget.
