Hello B&R Community!
I received a few questions from customers about the Year 2038 problem and the concerns about it, so I wanted to share with you how this is solved in the context of B&R Automation Runtime.
What is the Year 2038 problem?
Some systems store time as the number of seconds since 1 January 1970, 00:00:00 UTC.
If this value is stored as a signed 32-bit integer, the maximum value is 2,147,483,647 seconds, which corresponds to 19 January 2038, 03:14:07 UTC.
After that, the value can overflow and be interpreted incorrectly, which may lead to wrong dates or time calculations.
For more background, see:
https://en.wikipedia.org/wiki/Year_2038_problem
Is this issue solved on B&R systems?
Yes. The operating system underlying Automation Runtime 6.x, based on VxWorks 7.x, has solved the Y2038 problem.
A 64-bit data type is used in the underlying operating system. In Automation Runtime, an unsigned 32-bit data type is used with the limits documented in our AS Online Help:
Limitations to date time setting
Filipe
