Thank you, I installed it successfully and transferred the project again.
Is the test function from within Automation Studio compatible with CANBUS?
When I am right clicking the ACOPOS in the System Designer and select “watch”, I receive the error message you can see below:
I was receiving the same error before downgrading to 2.52.
This can be either a compatibility issue or a wrong CAN configuration I suppose, but an additional feedback would help.
