Hi there,
I am using X20BC00E3 as Profinet coupler to access IO modules from Siemens PLC.
While going through manual i found that the firmware version should be 1.6.
My current firmware is 1.0
Where will i get file to upgrade firmware.
Please suggest.
Thanks in advance.
This firmware file is available on request only from second level support. I recommend reaching out to your local B&R support channel as I’m not sure if anyone is able to share that here.
