I downloaded the newest AS6 - Version but setup of AS - Code terminates with the following Error Message:
Any idea ?
Manfred
seunghwa
(Seunghwa Hyun)
December 15, 2025, 8:21am
2
Hello, I had same problem and I solved it below…
Delete [S0109] script of Automation Studio.ini file and save this
Restart AS6.5 installer
Manual install Automation Studio Code
Best Regards,
Are you using AdminByRequest or some other tool to grant temporary admin rights?
Rens_B
(Rens B)
December 15, 2025, 8:50am
4
I’m getting the exact same error and not using AdminByRequest or anything
ok, this might be a certificate issue. We are already looking into it. I will give an update ASAP.
Thanks for Workaround!
I solved the problem by replacing the “AutomationStudioCode.exe” with the Version from the AS6.3.4.31 Setup and then Manual Installed V6.5.0.
The problem is, that the issuer of a certificate in the certificate - chain could not be found:
The workaround works perfectly for me.
After that, I executed the AS Code exe separately from the installation package.
(Even if it does not sound very trustworthy that the signature of this exe is not from B&R )
New signed version will be online most likely tomorrow
Rens_B
(Rens B)
December 16, 2025, 9:13am
9
New version is online, versio 6.5.306 and works like a charm.
