I am using a tilt sensor JN2100 Canopen which is standard and not SAFE. But my PLC is SAFE. X90CP154-S.
I have this error and do I have to use SAFE sensor?
Hi Saeed,
This error is just telling you that there is no safety application running on the safety CPU of your X90; it’s not related specifically to the sensor. I don’t think this will affect the reading of the sensor, but you will need to commission a safety application in order to set any of the X90’s outputs. You can create, compile, and commission a blank safety project if you don’t need to run any safety code at the moment and that will stop these errors from occuring.
Thank you Marcus.
You were right. The problem was from NODE ID.
