Compiling example project in AS 4.7
I tried to compile an example project and got the error “Could not find Automation Runtime directory D4.26.” I am using Automation Studio 4.7.2.98. Does anyone know what could be the issue?
Thanks and Regards,
Kenneth
The project you are using is using AR version D4.26 which seems to be not installed on your PC
So either you switch to a valid installed version (Project - change runtime verison) or you use Tools - upgrades to download D4.26
best regrards
Oliver
