Hi, I have problem with the Panel PC 900, the screensaver is not activated. Before the screen has active after 10 minutes, if don’t touch a screen. I would like to know how to activate it.
ok. what OS is used there and what have you changed?
..but screensaver and turn display off is not the same functionality.
Summary generated by AI:
Screensaver:
- What it does: Shows moving images, animations, or patterns after a period of inactivity.
- Purpose (originally): Prevent image burn-in on CRT or plasma monitors.
- Modern use: Mostly aesthetic or used for locking the screen after idle time.
- Display remains ON.
- Uses more power (especially with animations or 3D effects).
Turn Display Off:
- What it does: Completely turns off the monitor after a set time of inactivity.
- Purpose: Saves power and extends screen life (especially with LCD/LED displays).
- Display is OFF.
- More energy-efficient than a screensaver.
Which One to Use?
- For power saving, prefer “turn display off.”
- For locking the screen with a nice animation, use screensaver with password.
- You can use both — e.g., screensaver after 5 min, turn off display after 10 min.
So, I think you turn off the display before the screensaver is activated, and that is why screensaver no longer works for you.
